Let's say you have a film clip that includes a blank space on a wall. You want to add some lettering that appears to be on the wall, but the problem is the image isn't perfectly still. What kind of function or app would have the lettering follow the movement of the wall exactly so it doesn't appear that the wall is moving under the lettering?
You could use compositing software like After Effects. You would use the built in tracker or mocha to generate motion data and apply it to a new layer (your lettering), so it moves as the camera point of view moves, as if it was on the wall. The motion data can use perspective, rotation and planes so the overlayed image shrinks/grows/rotates near perfectly
Another method is to use a NLE like Premiere or Vegas, and move the layer and keyframe it manually. They do not have as many masking and effects options as After Effects, so the end result may not look as authentic, and it's more difficult to do using them , but it still can be done if you're patient
how to make the a4 background fit the whole paper ?
By freestyler9 in forum ComputerReplies: 3Last Post: 27th Feb 2010, 16:44 -
new videos with silver backings and see threw lettering
By gilly in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 07:25 -
How to make a moving .GIF image?
By Jeikobu in forum MacReplies: 4Last Post: 15th Aug 2008, 11:28 -
quality with pic zoom in and moving background?
By video_enthusiast07 in forum EditingReplies: 0Last Post: 11th Nov 2007, 11:32 -
Moving Picture and background question.
By video_enthusiast07 in forum EditingReplies: 3Last Post: 21st Jul 2007, 22:22
