I'm trying to convert from DVCPROHD to a codec and container that is compatible with most systems. The clips are 1280x1024 with video bitrate of 93 mbit/s and audio bitrate of 1137 kb/s. I feel ffmpeg is the tool for the job as so far it is the only encoder/decoder (that I've found so far) that can decode DVCPROHD. But I have a few questions:
1. What is the most compatible video/audio codec/container combination? High bitrates aren't a problem.
2. I really don't care about compression, I want as lossless a conversion as possible. Is there a practical bitrate limit to lossless(ness)?
3. I seem to have trouble with ffmpeg audio bitrates. Any encoding above 128k removes the audio. Ideas?
(4) If any has worked with DVCPROHD you'll know that there are 4 streams: 1 video, 2 audio, and 1 data. Any recommendations on the best way to consolidate the audio? and is the data stream necessary?
Thanks a lot!
Harrison
For what purpose ? Editing ? Viewing ?
Compatibility covers a lot of ground. It means having the right codecs to play the files back, it means having a format that does not require huge amounts of processing power to decode and display, and it may also mean using a lower resolution to allow for slower or lower resolution displays.Read my blog here.
I'm converting the clips for a colleague. I'm pretty sure he is going to use them in an HD documentary that he is editing. His software apparently isn't the most modern so he asked for the clips in a relatively compatible format. I do know that his hardware is generally top of the line so processing power isn't really a problem.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
how to set max bitrate in dvd architect
By ejparle in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2011, 17:44 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 12:29 -
At what bitrate does mpeg4 become lossless?
By sevenlayercookie in forum Video ConversionReplies: 1Last Post: 12th May 2009, 09:34
