  1. Do wireless (WLAN) signals go through walls or bounce off the walls?
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    both. You will experience a drop off of signal strength though walls but the amount will depend on the composition of the wall structure.
    Buy My Books
  3. Most walls pretty transparent, metal is bad. Certain stucco installations have a backing much like chicken wire that can cut reception dramatically. Glass is almost completely transparent. As I guess it's supposed to be.
  4. Member Number Six's Avatar
    Mar 2008
    It works the same way that any radio signal works, but it has a very short range to keep it contained in a small area.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
