I'm starting to transfer all my old VHS tapes to DVD, and in doing this I've decided to play through my DV camcorder and record via WinDV. The problem is that the resulting .AVI/DV gradually strays out of audio sync by the end of the 2 hours. The sync error is about 1 to 2 seconds. I googled and saw that Type 1 capture was better, and I tried that but no luck, the audio still strays out of sync. There are no dropped frames!
UPDATE: OK, I double checked the AVI in TMPGEnc cut edit window (VirtualDubMod does not play Type 1 DV) and it appears the Type 1 AVI/DV is perfectly fine and it is strictly a TMPGEnc encoder error. With Type 2 AVI it was definitely a WinDV problem as the AVI was out of sync so I thought the same thing was happening here. Gah. OK, I will start the appropriate TMPEGEnc thread elsewhere.
Tim
Results 1 to 1 of 1
Is anyone else having problems with MeGUI update?
By Xpenguin17 in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2010, 18:44 -
Microsoft feature -Automated problem developer. Win7 vs Sony HC90 and WinDV
By drewzor in forum Capturing and VCRReplies: 3Last Post: 25th Mar 2010, 11:47 -
WinDV audio problem
By Somej in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 17th Feb 2010, 20:56 -
Problem with capping on my comp with WinDV and advc-100
By MikeMGMVE in forum Capturing and VCRReplies: 3Last Post: 2nd Oct 2008, 13:19 -
WinDV Capturing Problem
By ViperUKR in forum Capturing and VCRReplies: 12Last Post: 26th Jul 2007, 23:14
