    May 2009
    I think it's a funny video of my mate from some time ago, And would really appreciate any help or points in the right direction to fix it!
    Here's The File :
    http://rapidshare.com/files/229879559/MOV01152_REPAIR_NEEDED.MP4.html
    (sorry its rapidshare with only 10 downloads)
    When I try and play it with quicktime all it comes up with is "Error -2048 Couldn't Open The File "(filename)" because it is not a file that quicktime understands"
    I've scoured the net to no avial...
    cheers xxmaxx
  2. see if vlc or avidemux will open it. also try checking it with mediainfo.
    May 2009
    Nope it doesn't open up in either I'v ealready tried. i'm pretty sure the actual file is corrupt because my phone ran out of battery while it was filming and switched off....
    Meida Info doesn't say much, just it's 3GPP Media Release 5 (Codec ID 3gp5) & it's 3.66 mb.... lol
    Even if the only savable bit is the audio I'll still be happy
    xxmaxx
  4. good luck but no one has much luck fixing broken 3gp files.
  5. Mod Neophyte redwudz's Avatar
    USA
    Not restoration. Moving to Newbie/General Forum.
