Ok some people are saying you can't get cd quality or better mp3's which i dont think is true, what's your opinion?
CD fidelity, no....unless your mp3 encoder can go up to 1411kbps.
CD quality on the other hand is pretty subjective. I'm reasonably happy with 128Kbps, although I would say that my CD-quality point is more like 192 or 256Kbps for MP3. -
I would say encoding with LAME 3.91 using either of the below command lines:
--alt-preset standard
--alt-preset extreme
--alt-preset insane
Is pretty damn close to CD quality. Actualy, most would consider it CD-Quality, since you virtually cannot tell the difference between the original, and the encoded MP3.
I myself am very, very picky about the sound quality of MP3s, and I can hear frequencies up to 22khz. When using "--alt-preset standard" I virtually cannot tell the difference between the original and encoded file. This command line is also considered the most optimal for quality/size in the r3mix.net forums.
Thanks for your time.
Guiboche -
I'm as happy as a pig in shit with 192Kbps upwards.
I tend to download / encode at 192 all the time coz it gives a happy medium between quality and filesize. -
As most people listen to Mp3's on a computer, the difference is negligable if you use relatively high bitrate MP3. However, if you have a good quailty hifi then the difference is easily noticable; the better quailty your audio equipment the more you should be able to detect the difference.Ok some people are saying you can't get cd quality or better mp3's which i dont think is true, what's your opinion?
I find that MP3 at 192Kbps sounds ok on a computer - I use 256kbps as I find it sounds a little better than 192kbps.
To fully appreciate CD audio, you have to listen to it through good quality hifi equipment.
Recording High Quality Sound on PC
By evil nemesis in forum EditingReplies: 11Last Post: 25th Feb 2012, 15:36 -
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 21:27 -
How to improve the sound quality of this video?
By awaisuk in forum EditingReplies: 2Last Post: 19th Nov 2007, 23:15 -
sound quality
By ecos in forum Newbie / General discussionsReplies: 10Last Post: 1st Jul 2007, 18:34
