Hi guys, i got a big problem, when i try to demux a recorded show with PVAStrumento in order to cut the comercials with Mpeg2Cut the audio get out of sync, the problem is with the demuxing program because i demuxed the same file with DGIndex and it went ok, but the Mpeg2Cut only opens the files that come out of PVAStrumento so can't edit the video, someone can help me with this? The source file it's an MPEG2 video recorded with a VisionPlus 1020A.
I've had that issue a long time ago with PVAStrumento. VideoReDO seemed to be the best, but it's not free. If you do a lot of mpeg2 captures, the program is well worth the price.
Cutterman is another program that I've had good success with.
Edit - it's not Cutterman it is Cuttermaran
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
Not usre I understand your process, MPG2Cut does not require demuxed files. PVAStrumento seems to do some odd things to the files to "correct" certain issues, this is probably where the problem is happening. When you say this is the only output the editor accepts, you just haven't tried enough other options.
Demux and Remux with something else, you may need to try several different progs before finding something that works.
I have been using MPG2cut2 (newer version) to cut captured files for years, from different capture cards. Never had an issue. -
Thanks guys for your help, i've tried proyectX as ronnylov said, and works for me, but thank you all, see'ya.
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53 -
How to demux
By php111 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Aug 2007, 18:07
