Whats the best way to convert a MKV to DVD9-DL spanning to (2) discs? The Mkv is 13gb so wanted to put it on (2) DVD-DL discs...
I used ConvertXtoDvd setting it to Dvd9(8100gb) with Mkv's that were 6-8Gb, it does have a custom setting so what would happen if you set the custom setting to 16200Gb? Can you burn this to (2) DVD-DL discs?
Maybe you would have to use DvdShrink on the VIDEO_TS folder to cut the video in 1/2 and save as two different ISO's...
What are avchd-dvd's? I heard using Vegas Pro or Roxio software you can burn HD on a DVD9 playable on a blueray player(limited to certain amount of time)
I do own a blueray player and HDTV(1080p), the Blank Blueray discs are still too expensive!...
Thanks!
Results 1 to 11 of 11
I've done this a few times.
Usually I've ran uncropmkv as some mkvs have trouble especially with the aspect ratio.
Then I use tsmuxer to output in blu ray/avchd format. And finally burn with folders with Imgburn.
But for those that need to span 2 dics I use popBD to output the bluray/avchd folders with custom split.
BDrebuilder may also work as it can split also but I haven't tried it for this purpose yet. -
What are you trying to create ? A DVD ?
What is the running time of the movie ?
To create two DVD structures you will have to first split the MKV file, then convert each part.
However do not confuse the 13GB file size of the MKV with the size required to put the same movie onto DVD. Unless it is a 6 hour epic, you will most likely only need a single DL disc.Read my blog here.
Interesting input gents...
I did find these guides for help with avchd...
Using tsMuxeR
http://www.bitburners.com/articles/convert-mkv-files-to-blu-ray-or-avchd-for-playstati...-tsmuxer/4019/
Using mkv2vob
http://www.bitburners.com/articles/convert-mkv-to-usb-avchd-for-playstation-3-using-mkv2vob/4384/ -
DVD9, so like you pointed out the org size is just from the resolution source creating a much bigger file, and convertXtoDVD would be fine at DVD9?...Originally Posted by guns1inger
Was just wondering too how to split an Mkv file for reference. -
Why does popBD and uncropmkv both point to the same link of a different name multiAVCHD?Originally Posted by odwoh
It will happily fit on a single DL disc when converted to DVD compliance.
A long winded way to split the file would be TSMuxerGui/TSMuxer to split and create a .M2TS file, then use Xvid4PSP in Copy mode to create new MKV files from each part. However this will lose any subs in the file.Read my blog here.
I quick glanced, time, time, one needs more time when busy with video processing.Originally Posted by guns1inger
I FULLY plan on eye checking that site!
Thanks to all participants!
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 08:55 -
Dvd9 to mkv help
By HACKJACK in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2011, 01:23 -
10gb mkv to 2x dvd9?
By cv65user in forum Video ConversionReplies: 2Last Post: 3rd Dec 2010, 10:48 -
MKV to DVD9
By juicemaker in forum Video ConversionReplies: 5Last Post: 24th Dec 2009, 15:28 -
Mkv to DVD9...Pls Help !
By john_triton in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2008, 07:57
