With this program, almost every single line has at least one mistake. That means I have to go through and fix every line throughout all the footage. I don't think there's anything that can be done to get that working better, so, does anybody know of a program as simple and effective as this but does a better job? I tried SubRip before this program and it was just too confusing...
				Results 1 to 19 of 19
	Is it the automatic OCR you're talking about? Yeah, it sucks. You should be OCRing manually with SubRip. You think SubRip is confusing? Tedious maybe, but it's pretty simple in principle. Open the VOBs or the IFO, tick "Subpictures to Text via OCR", choose the output format (SRT, SSA, what?) by hitting the blue jigsaw puzzle piece-looking box, and then hit Start. It goes slowly at first, but picks up considerably after you get all the letters and numbers typed in once.
 Here's a guide:
 http://www.doom9.org/subrip.htm
	Hmm.. Well, it was long ago, so maybe because of the tediousness I thought I was doing something wrong. Yeah, I'm going to try again. From what you said, it looks like SubRip learns what the letters are based on your corrections as you go along unlike in DVDSubEdit. Is that right?Originally Posted by manono
	Ideally you type each one in once - once per capital letter, once per small letter, once per number, plus the punctuation and other odds and ends. And if there are italics, then there's another set of typing.Is that right?
	Oh. I see, cool. Umm, if I have a different source with the same subtitles style, would I be able to save that typing or whatever for other files? Or.. would it have to be done for each file individually?Originally Posted by manono
	Yeah, save the character matrix and the next time you have the same style of subs, you'll do little or no typing.Umm, if I have a different source with the same subtitles style, would I be able to save that typing or whatever for other files?
 There are character matrix files with many, many different kinds of subs already worked out floating around. Track one down and with any luck you may not have to do much typing at all.
	Lol. Where would be the ideal place to search for that?Originally Posted by manono
	Hehe, I was just searching myself:
 http://www.mediafire.com/file/mndwnjymyyt/ai4spam.rar
 Unrar it and stick it in the ChMatrix folder in SubRip. Then when the first letter shows up to be typed, hit the "existing matrix that match for this" button. Hope for the best.
	Oh, I see. This is like an all-in-one thing where they did the character matrix for many sources, one of those sources likely to be similar to the one I might have. Lol, alright, thank you very much.Originally Posted by manono
	I'm following the guide just in case now (cause nothing was happening, but there's nothing different from what I did. It's not finding any subtitles like DVDSubEdit did. I don't have the IFOs so I'm just using the VOBs. If DVDSubEdit was able to identify them, so then so should SubRip right?... It's going through the whole thing without a single pause and no subtitles, nothing...Originally Posted by manono
 EDIT: I just tried it with the IFO and it still doesn't work.
	This is why I wasn't getting around to subtitles this whole time. Because it's not worth all that just for subs.. Maybe it's my version of SubRip. As I said, it works with DVDSubEdit so I shouldn't have to be doing anything extra just for SubRip.Originally Posted by manono
	I was just editing. Check the drop-down box to see if there are any sub streams besides the first empty (?) one.
	You're right - very strange. If DVDSubEdit can see them, then so should SubRip. I've never had that particular problem so I don't know the solution, other than to suggest what I did before - try and extract the VobSubs.
 There's another way to OCR, and that's by using SubResynch (comes included with the VobSub package). But it requires the VobSubs as input.
	Well, I don't know anything about VobSub (though I want to), so I won't go there. Not now anyways... I'm going to try to download a different version of SubRip.Originally Posted by manono
 EDIT: Yes, it was my version of SubRip... Ugh, I hate crap like that. Anyway, thanks.
	Wth?... I opened the program again and wanted to rip the subs again from the same file, just to see if it would work without interruptions after I had loaded the Character Matrix that I saved. And it wasn't working again. It went through the whole thing without any result just like before. I didn't do anything different. I don't understand.. Makes absolutely no sense.Originally Posted by Typhoon859
	Lol, that's ok. It's not a very rational problem. I don't think it can be figured out. The only factor that I see that could be affecting the program in such a way is the operating system somehow. Dunno... There's nothing else that changes...Originally Posted by manono
  problem with dvdsubeditBy pcb in forum SubtitleReplies: 2Last Post: 6th Jul 2010, 01:14
  Error in DVDSubedit when re-timing subtitlesBy kpic in forum SubtitleReplies: 2Last Post: 22nd Feb 2010, 05:08
  DVDSubEdit time error in .srtBy Arlo in forum SubtitleReplies: 5Last Post: 2nd Feb 2009, 04:18
  Loading subs with dvdsubeditBy aruwin in forum SubtitleReplies: 2Last Post: 24th Nov 2008, 04:00
  DVDSubEdit - Subtitles OCR ProblemBy kwazi in forum SubtitleReplies: 1Last Post: 28th Nov 2007, 07:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
