I have downloaded some AVI's and am trying to encode them with TMPGEnc. When I enter the file as the source, I get a message that says it is unsupported or cannot open. I tried to use the AVISynth method of an earlier post with no success. Can someone tell me why this wont work? Is it something with frame rates? The AVI is done at 20 fps. Can I change this in TMPGEnc? Please help. I am flooded with AVI's I cannot do anything with. Thanks
Gary
that is 100% correct. sorry to say but you cant create any kind of decent VCD using SMR movies as a source.Originally Posted by Hogringer
that is unless you dont mind it duplicating frames to create the proper frame rate and massive amounts of macroblocks because you are creating a file with a bitrate of 1150 from of a file with a bitrate of 350. that means you are trying to triple the information in the file.
sorry dude they are good to see the movie on your computer but not good enough to make a VCD.
BTW the reason you get the unsupported message is because despite the file extension it is in all actuality an asf file and asf is not supported. you may be able to get it to work with an older version of TMPGEnc but we are talkin WAY to much effort for a really poor result.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 19:27 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 22:32 -
Problems with Vimeo Encoding
By Xenon77 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Apr 2009, 12:04 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 12:50 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30
