Odd thing happened when backing up recently using DVD Fab. Backed up (main movie only) then burned using DVD Shrink/DVD Decrypter combo. When I went to play the DVD, it was there in its entirety but the chapters were jumbled all over the place. For example, chapter 5 was the opening credits, chapter 1 was something about 10 minutes into the movie....weird. Any idea what could have caused that because I didn't rearange anything...
Results 1 to 14 of 14
Sure, had that happen a couple of months ago, but I forget which release it was, at the moment.
Anyway, it's probably a new protection scheme and Fab isn't yet updated to deal with it specifically. As I see it, wait a week or two for the next update to DVDFab. Or...try running FixVTS on the Fab rip, before opening the rip in DVDShrink. That's worked for me in the past. Alternatively, try FixVTS on a full disc rip if you haven't tried that already. (Main movie mode is chancy with new protections on Fab). Then open in Shrink.
P.S. Oh yeah it was WALL_E. If interested in some workarounds, do a search for threads on that movie.Pull! Bang! Darn! -
I've heard of (but never seen) DVDs with a mixed-up chapter structure as a type of psuedo copy-protection. I've even seen people suggest it here (probably in the "How do I copy-protect my home made DVDs?" thread).
Pull! Bang! Darn!
Mmmmmm could be rabbit....could beee.....Originally Posted by dialysis1a
Thanks to all. I just went to download updates to DVD Fab and realized I don't see any kind of link to check for newer versions. But I am using the freeware version. Is it not an option on the free version and so I have to uninstall and re-download or am I missing a menu somewhere?
should be in common settings/general - check for updates now.
or the direct link in the tools section here works fine. just d/l and install over the old one.
https://www.videohelp.com/tools/DVDFab_Decrypter -
Last time I looked it only offered to update to the full paid version?Originally Posted by minidv2dvd
DVD Fab HD
By GAR in forum Newbie / General discussionsReplies: 9Last Post: 10th Sep 2010, 18:38 -
Dvd Fab hd
By durkinjt in forum Blu-ray RippingReplies: 2Last Post: 29th Nov 2009, 17:43 -
DVD FAB HD
By herdbull in forum DVD RippingReplies: 1Last Post: 11th Mar 2009, 09:47 -
dvd fab
By kattiemylady in forum DVD RippingReplies: 6Last Post: 28th Dec 2008, 09:47 -
DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
By MacPCConsultants in forum DVD RippingReplies: 7Last Post: 4th Mar 2008, 03:39
I strongly suspect if you do a full disc rip, run
