Results 1 to 11 of 11
  1. I have question regarding Mozilla,all the time when I close and reopen the browser I have to log in to all websites.
    What setting I need to change?
    Probably Tools->Options->Privacy->Always clear my private data when I close Firefox.
  3. tools/options/security - check remember passwords.
  4. Originally Posted by minidv2dvd
    [edit] baldrick is probably right, try unchecking clear private data..
  5. Actually I've installed Super AntiSpyware and I think I have this problem since then.
    Talking about SAS, it loads quite slow when I start the pc, any idea why?
  6. Originally Posted by Baldrick
    It is not on
  7. I have Firefox set to:
    1) Clear private data on exit. (Tools --> Options --> Privacy).
    2) Remember pass words. (Tools --> Options --> Security).
    No problem with automatic login.
    As to SAS, by default it's checking for updates when booting up computer. I have it set to defaults (no startup scan however), and yes, it slows the boot somewhat.
    Pull! Bang! Darn!
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Do you have it set to delete cookies ??
    Once you are logged you should stay logged in.
    I NEVER use save passwords and i stay logged into tons of sites even after shutting my PC off.
    A few sites i frequent have like a 2 week period where they expire and i have to re-log in.
  9. Originally Posted by Noahtuck
    Today it happened again, yesterday I was logged in some sites and now I have to log in again.
    I checked the mozilla settings but everything seems ok, but still I don't know where is this coming from...
    Aug 2008
    The Moon
    There is a Firefox bug, I had the same problem, but this simple fix worked for me.
    This may or may not be your problem, but it worked for me.
  11. Originally Posted by ZQX
    Thanks for the link. Hopefully will work also for me
