I guess I still consider myself a newbie at this point, but I've had success using TMPGE for conversion of raw captured files from my Optura Pi. I completed my first project using Premiere 6.01 and TMPGE won't read the avi file. I used the standard (default) export settings in Premiere. Any thoughts?
Results 1 to 9 of 9
Did you install the avisynth premeire plugin?
http://www.vcdhelp.com/premiereavisynth.htm -
That's a "no" and I'd guess that's the problem. I'm on it.....I'll post up results.Originally Posted by g0dZpr0fi7
Ok, installed the plugins, and I don't have the selection for the plugin when setting up the export rules. I verified the plugin file was in the appropriate folder, although there were subfolders in the Plugin directory under Premiere. Any thoughts on how to get this plugin to show up?
did you export the video and audio separately, tpmgenc wont read the dv file when video/audio are exported together.
with avisynth you have to save a notepad file with the exported file name, and save the note file as a .avs for TPMGEnc to read it. -
No, I exported the entire project. Wasn't aware that I had to separate the audio from the video. One thing I've learned. This isn't point and click that's for sure.
no its not, and once you think you have it, it doesn't work all over again, trust me. anyways hope it all works for you now
Just used Premiere 6.01 to capture (720x480) a 2:25 min movie (13 Days) off digital cable in the AVI format, opend with VirturalDub, resize to 352x240, did a Frameserve to TMPGEnc. Worked like a champ, VCD came out great. Used the Standard VCD Templates in TMPGEnc 2.52
Bud
No Audio on exported clip from speeded up footage in Premiere.
By kestifer in forum Newbie / General discussionsReplies: 6Last Post: 10th Jun 2012, 18:27 -
dv exported from premiere isn't microsoft dv, it is sony dv; why?
By codemaster in forum EditingReplies: 2Last Post: 31st Dec 2011, 09:28 -
strange sounds in audio exported from premiere pro cs3
By codemaster in forum EditingReplies: 0Last Post: 25th Jan 2011, 19:57 -
Exported AVI from Premiere pro2 have problem!!!
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2008, 21:29 -
DVD exported from Adobe Premiere Elements Help
By Captain Satellite in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 19:09
