Hi!
I am new to this forum, so please excuse my ignorance.
I have captured a LOW-resolution LOW-quality realmedia video, via my computers svideo-out to a DV tape. Then I read the DV tape back into the computer, and author a DVD from it. Then I get interlace problems, which makes it really irritating to watch. This is especially stupid since I could cope with 25 or 30 fps with a LOW resolution. The video is not the point, it is the audio, since it is a very good lecture.
I think that one way to go could be to convert the DV data by dropping all even (or odd) fields. Is there any free or cheap software that could do that?
Or do you have a better solution to my problem?
Thanks!
Results 1 to 9 of 9
It is on the PC, I don't know how it looks on a TV, I don't have any.
However, other DVD's look good when played on the PC. -
Go from Real to MPEG-2, skip all the in/out DV stuff.
Will you suggest a software that does that?Originally Posted by lordsmurf
Thanks. -
EO Video
Is there actually no way of doing this easily with a free software?
I mean, Just removing odd frames and duplicate the even ones, in the DV file.
(Sorry for reposting.) -
Most players include on-the-fly deinterlacing while you play a DV AVI. If you're making a DVD you should ignore the comb artifacts and make an interlaced DVD. It will look fine when played on TV.
If you reall want to deinterlace get the latest VirtualDub and do the following
1) File -> Open Video File
2) Video -> Filters -> Add -> Deinterlace -> choose from many (Yadif, ELA, etc.)
3) Video -> Compression -> pick your codec
4) File -> Save as AVI -
Do you have an actual "realmedia video" file that you started with? DVD Flick (free) may be able to directly convert it to DVD.Originally Posted by TheOtherSwede
http://www.dvdflick.net/features.php
Can't get rid of interlace lines
By MacFast in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 22:41 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Help with keeping quality for archiving my video files. Interlace source
By drewzor in forum Video ConversionReplies: 11Last Post: 8th Mar 2010, 19:32 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Why am I getting crappy DVD encoding? (interlace problems, etc)
By timmus in forum Authoring (DVD)Replies: 15Last Post: 14th Apr 2008, 10:23
