My brother has a Sony HDR-HC9. I am making a DVD for his business, but I'm not using the footage in HD. I'm capturing it in SD via the iLink cable. Sometimes he has his camera and I need to record some footage, so I was looking at investing in a MiniDV SD camera for myself.
My question is this: if I purchase a standard SD MiniDV camcorder will the footage be virtually the same after capture as the HDR-HC9?
In other words, is footage recorded in HD and captured to the computer in SD better or equal quality as SD recorded footage?
I guess I explained that correctly..I kind of got confused myself typing it out. :P
Complicated issues.Originally Posted by C_Copeland
A camcorder has two parts a cam and a corder. Quality varies most on the "cam" end. DV camcorders can be had for $2,000 or $20,000 the main difference being the cam lens, sensors and processing. The recorder part is similar.
The HDR-HC9 can shoot HD or SD. If you shoot HD but downscale in the camera to 720x480i DV, the scaler determines most of the quality compromise. So the question becomes can a cheap HD cam beat a more expensive DV cam? Most of the difference will be in low light where the large glass DV camcorder wins. The HDR-HC9 will beat most cheap DV cams in outdoor light.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
rather than than a cheap minidv sd cam, nobody is going to be satisfied with, you might consider a canon hv30. shoots hd/sd like the hc9, but is a better overall cam, and cheaper to boot.
The advantage of the Canon HV20/HV30 is it will play DV or HDV format tapes from the HDR-HC9. HDV format will be easier to edit vs AVCHD.
Thank you for the replies. I suspected as much, but I wanted to ask the experts here.
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
having problems with a dvd i recorded
By bigv1385 in forum MediaReplies: 1Last Post: 23rd Apr 2010, 14:58 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06 -
No audio on recorded DVDs
By panko1979 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 5th Jul 2007, 10:47 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 08:57
