I know this question might seem repeated, as I already searched "forums", "guides" and "tools"!!
But I really got lost in the topics....
I will make myself clear here, and I will wait for an expert to guide me.
I saw videos posted on the internet, it was ripped from Bluray Disc (BD) into x264 AVI, the quality was much more better than DivX and even smaller(500 MB for 120 minutes)
* I attached a screenshot for the video*
http://i40.tinypic.com/fvx4w.jpg
My case:
Source: AVI video (XviD or DivX)
Target: AVI video (MKV could be acceptable) with x264 (will be played on PC)
Quality vs Size: I want it smaller in size and not to lose much quality![]()
Time: It's all about time, I don't need a tool to convert 100-minutes video in another 100 minutes!
--my PC is 3.4 processor with 1 GB ram, so 30 minutes would be fair--
Tool: One single tool plz, not bunch of them
Some will say: "beggars can't be choosers", but I really need it that way...
And what if my source was Bluray? But that's another issue which I don't need now. But If a tool can handle both Bluray and XviD (or DivX), I will be more than grateful.
Coz knowledge is everything... left ;)
http://mriddler.blogspot.com -
Converting your AVI to h.264 isn't going to improve the quality at all. Go back to your original BD. You can probably shrink the Divx/Xvid AVI by about 1/3 using h.264 without losing too much quality. I'd use x264 and x264gui to make an MKV file -- assuming your playback device can handle MKV.
I don't want to improve the quality, I just mentioned that x264 vs DivX when ripping from BD just as an example.Originally Posted by jagabo
As I said:
My source is DivX/XviD AVI
Using H.264?? It isn't what I asked for, as I thought that x264 is betterOriginally Posted by jagabo
If H.264 can really shrink size to 1/3, plz tell me how?
Do you mean that tool "Leimings x264 GUI"?Originally Posted by jagaboCoz knowledge is everything... left ;)
x264 is a freeware h.264 encoder. h.264 is a format, mpeg4 part10. Just like divx/xvid is a format, mpeg4 part 2Using H.264?? It isn't what I asked for, as I thought that x264 is better
Can't be done with your PC, expect 3-5hours--my PC is 3.4 processor with 1 GB ram, so 30 minutes would be fair--
You can't shrink the size without quality loss. Re-encoding using a lossy codec only degrades quality. You are using a low quality xvid 2nd generation video as a source, instead of the original blu-ray. If you started with the original blu-ray you could do it with much better quality
I would leave it as is.
AVI Motion JPEG to x264 in Matroska MKV container
By Michielvsb in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 04:12 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 19:31 -
Please help! Corrupted x264 video preview/output in AviDemux
By bigshotceo in forum EditingReplies: 1Last Post: 31st Dec 2008, 09:48 -
Converting or demuxing MKV's to another container using x264 or vc-1
By dm_0001 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2008, 15:19 -
change x264 container without recode?
By rockstar in forum Video ConversionReplies: 12Last Post: 11th May 2007, 01:31
