I got some dvd quality videos and am trying to view them on my 1920x1200 screen and when I maximize the window i can tell that the quality gets worse. Is there any software to upscale these videos so that they will appear better when in full screen?
There is, Deemon Video Enhancer, several others, but it is painstakingly slow.
"Quality is cool, but don't forget... Content is King!" -
Which display card are you using?
How is it connected?
What is your monitor? ...and its native resolution?
DVD is 720x480. Your display card upscales to the output resolution.
Software upscale isn't going to make the DVD equivalent to HD.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Geforce 8800 - DVIOriginally Posted by edDV
my monitor is a hanns G 1920x1200. The dvd videos in question are only 10 to 20mins long. If the difference in quality is obvious I would upscale them -
I should also mention that currently my graphic card alone doesnt do any upscaling work with my dvd videos on my pc. Is there a program that would upscale them?
It is if you are watching full screen and not in a little 720x480 window. The question is what algorithm is it using. Probably bilinear or bicubic.Originally Posted by CheekyKid
I've never used thier software but I find the Deemon's web site to be disengenous, showing nearest neighbor enlargements next to their (hand picked) super resolution results. I don't trust them because of it. At least they show more realistic results if you dig down a bit:
http://www.thedeemon.com/articles/video_upsize_methods_comparison.html
I hate their font too!
Upscaling Standard definition videos with software
By TheOncomingStorm in forum User guidesReplies: 4Last Post: 30th Apr 2012, 12:32 -
Upscaling DV to HD
By carlmart in forum Video ConversionReplies: 25Last Post: 27th Mar 2010, 08:29 -
Video Upscaling?
By Xdecade in forum EditingReplies: 9Last Post: 21st Jan 2010, 00:56 -
Best upscaling software
By Spectral Fusion in forum Video ConversionReplies: 10Last Post: 15th Oct 2009, 21:13 -
upscaling
By gunukhan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jul 2007, 13:08
