Ok, so some super famous dude came to our school, and I filmed him to my iPhone 3G using Cycoder. At the very last moment the phone turned off since it ran out of battery. I later charge it up, open cycoder and try to play the movie. It doesn't play. I copy it to my pc, and it won't open with VLC or Quicktime.
So I did some research, and found out that the MOV format wasn't finished, so some vital info was missing. Is there any program to fix it? I've already tried MPEG Stream Clip, so no point recomending me that.
Any help will be apreciated!
I can't be bothered to add a sig :p
Does it play in GOM ?
Nope, can't find the correct codec.Originally Posted by lordsmurf
Although it did give me this:
BINARY INFO
FileName : 1241165945.mov
Header Data :
00 00 00 14 66 74 79 70 71 74 20 20 00 00 02 00 ....ftypqt ....
71 74 20 20 00 00 00 08 77 69 64 65 00 00 00 00 qt ....wide....
6d 64 61 74 ff d8 ff e1 00 2a 00 00 00 00 6d 6a mdat.....*....mj
70 67 00 00 83 7a 00 00 83 7a 00 00 00 00 00 00 pg...z...z......
00 30 00 00 00 c9 00 00 00 b6 00 00 02 6d 00 00 .0...........m..
02 79 ff db 00 84 00 04 02 03 03 03 02 04 03 03 .y..............
03 04 04 04 04 06 0a 06 06 05 05 06 0c 08 09 07 ................
0a 0e 0c 0f 0f 0e 0c 0e 0d 10 12 17 13 10 11 15 ................
11 0d 0e 14 1b 14 15 17 18 19 1a 19 0f 13 1c 1e ................
1c 19 1e 17 19 19 18 01 04 04 04 06 05 06 0b 06 ................
06 0b 18 10 0e 10 18 18 18 18 18 18 18 18 18 18 ................
18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 ................
18 18 18 18 18 18 18 18 ff c0 00 11 08 01 20 01 .............. .
80 03 01 21 00 02 11 01 03 11 01 ff c4 01 a2 00 ...!............
00 01 05 01 01 01 01 01 01 00 00 00 00 00 00 00 ................
00 01 02 03 04 05 06 07 08 09 0a 0b 10 00 02 01 ................
03 03 02 04 03 05 05 04 04 00 00 01 7d 01 02 03 ............}...
00 04 11 05 12 21 31 41 06 13 51 61 07 22 71 14 .....!1A..Qa."q.
32 81 91 a1 08 23 42 b1 c1 15 52 d1 f0 24 33 62 2....#B...R..$3b
72 82 09 0a 16 17 18 19 1a 25 26 27 28 29 2a 34 r........%&'()*4
35 36 37 38 39 3a 43 44 45 46 47 48 49 4a 53 54 56789:CDEFGHIJST
55 56 57 58 59 5a 63 64 65 66 67 68 69 6a 73 74 UVWXYZcdefghijst
75 76 77 78 79 7a 83 84 85 86 87 88 89 8a 92 93 uvwxyz..........
94 95 96 97 98 99 9a a2 a3 a4 a5 a6 a7 a8 a9 aa ................
b2 b3 b4 b5 b6 b7 b8 b9 ba c2 c3 c4 c5 c6 c7 c8 ................
c9 ca d2 d3 d4 d5 d6 d7 d8 d9 da e1 e2 e3 e4 e5 ................
e6 e7 e8 e9 ea f1 f2 f3 f4 f5 f6 f7 f8 f9 fa 01 ................
00 03 01 01 01 01 01 01 01 01 01 00 00 00 00 00 ................
00 01 02 03 04 05 06 07 08 09 0a 0b 11 00 02 01 ................
02 04 04 03 04 07 05 04 04 00 01 02 77 00 01 02 ............w...
03 11 04 05 21 31 06 12 41 51 07 61 71 13 22 32 ....!1..AQ.aq."2
Does that help?I can't be bothered to add a sig :p -
The file may be too damaged.
Awww..... there is now way to repair the header?Originally Posted by lordsmurfI can't be bothered to add a sig :p
How to record HD TV?
By iRecycle in forum Capturing and VCRReplies: 19Last Post: 28th Nov 2014, 18:46 -
how do i record VCR to PC help
By shockwave972 in forum Capturing and VCRReplies: 1Last Post: 10th Apr 2010, 04:57 -
Record problem Samsung DVD-HR773
By alexfels in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Mar 2010, 06:45 -
Problem capturing mini dv audio w/ camcorder other than one used to record
By Nuzy in forum Capturing and VCRReplies: 18Last Post: 22nd Feb 2010, 05:35 -
Fraps Record Volume Problem
By WolfyBrandon in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2008, 06:41
