Alright so i've got a video that when played back produced no audio (which i wanted to extract, the video is near useless), and checking it with MediaInfo gave me the following info:
Audio
Format : RT29
Codec ID : 75
Codec ID/Info : Voxware RT29 (MetaSound)
Description of the codec : Voxware MetaSound - AC24V1 24.0 kbps, 22 kHz, Mono
Duration : 1h 1mn
Bit rate : 24.0 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Now i'd never heard of this codec, but checking online i found the decoder for it, and i can now hear the audio on the video. However, since i've no idea what container or extension this format would have, i have no idea how to go about extracting the raw audio.
I could just use something to convert it on the fly to WAV or MP3, but i'd prefer to be able to extract the raw mono file and work with that in an audio program.
So, does anyone know if it would be possible with any program?
Any audio editing program is going to have to decode and work with an uncompressed copy in memory, so you might as well pre-convert it to Mono LPCM wav (although I'd SRC it to 44.1kHz or 48kHz--depending upon intended outcome--for easier mixing workflow).
Extracting audio from flv
By Mike99 in forum AudioReplies: 30Last Post: 22nd Apr 2011, 08:31 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
voxware problem
By Szymus in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2008, 08:59 -
extracting audio from submenu
By juetenglord in forum Authoring (DVD)Replies: 3Last Post: 18th Feb 2008, 07:29
