i'm muxing xsub subtitles to my avi movies before watching them on my dvd, but with some movies, subtitles are not shown on tv.
i figured out that if i recompress these avi's (avirecomp or autogk) the subs then work, but some of the quality is lost.
is there any way to recompress avi with absolutely no quality loss?
Short answer - no.
Long answer - if you use a larger bitrate than the source then you can minimise the damage from re-encoding. You might also spend some time looking at the difference between the files that do not play, and the files that do, and try to work out why. There may be a solution that does not require re-encoding. MediaInfo is a good place to start. Post the output here is you cannot read it and make sense of it yourself.Read my blog here.
thanks for your reply.
i've downloaded mediainfo and extracted informations from two movies; the first one doesn't work, and the other one does.
Code:General Complete name : C:\Enemy_Of_The_State.avi Format : AVI Format/Info : Audio Video Interleave File size : 695 MiB Duration : 2h 1mn Overall bit rate : 800 Kbps Writing library : VirtualDub build 11583/release Video Format : MPEG-4 Visual Codec ID : DIV3 Codec ID/Hint : DivX 3 Low Duration : 2h 1mn Bit rate : 678 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4/3 Frame rate : 25.000 fps Resolution : 24 bits Bits/(Pixel*Frame) : 0.088 Stream size : 590 MiB (85%) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 112 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Video delay : 104ms Stream size : 97.2 MiB (14%) Alignment : Split accross interleaves Interleave, duration : 40 ms (1.00 video frame) Interleave, preload duration : 499 ms
Code:General Complete name : C:\Blood.Diamonds.CD1.avi Format : AVI Format/Info : Audio Video Interleave File size : 692 MiB Duration : 1h 10mn Overall bit rate : 1 365 Kbps Writing application : VirtualDubMod 1.5.10.2 (build 2542/release) Writing library : VirtualDubMod build 2542/release Video Format : MPEG-4 Visual Format profile : Streaming Video@L1 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 10mn Bit rate : 908 Kbps Width : 624 pixels Height : 256 pixels Display aspect ratio : 2.438 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.237 Stream size : 460 MiB (66%) Writing library : XviD 1.1.2 (UTC 2006-11-01) Audio Format : AC-3 Format/Info : Audio Coding 3 Codec ID : 2000 Duration : 1h 10mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : 17ms Stream size : 227 MiB (33%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 500 ms
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Quality loss from D V -AVI to other formats
By santolina in forum Video ConversionReplies: 20Last Post: 24th Jul 2009, 14:24 -
MKV to AVI without quality loss
By Markomaani in forum Video ConversionReplies: 10Last Post: 15th May 2009, 09:51 -
avi to MPEG quality loss?
By prcole18 in forum Video ConversionReplies: 1Last Post: 7th Oct 2008, 10:38 -
Avi to WMV without quality loss
By nabed4t in forum Video ConversionReplies: 1Last Post: 2nd Aug 2008, 03:20
