hi, how can I convert my DVD from NTSC to PAL - please tell me the best program to do this?
Results 1 to 16 of 16
It's also a waste of time. At least 90% of newer European players easily play NTSC discs....it is the region code on the discs people need to worry about.Originally Posted by jebinio
It's best to use a multi-system DVD player but you can also make a backup by using DVDFab Decrypter and ImgBurn,that way it removes the region code.If it still won't play then try this method:
https://forum.videohelp.com/topic221928.html -
It's not a waste of time, there's noticeable flicker in light colored backgrounds on PAL DVD's playing on NTSC systems.Originally Posted by MOVIEGEEK
ConvertXtoDVD does a fine job of converting and removing that flicker... -
That's a wonderful story....too bad it has nothing to do with the original poster's question.Originally Posted by ranosb
Does it convert an entire DVD including extras and menus from PAL to NTSC or just individual files?
Does it need another program to decrypt and rip the original DVD? -
Like your aviatar says "Confused".Originally Posted by hech54
Im recommending convertxtodvd and backing up its use, that it should be used despite dvd players can play both formats...
What was your useful post all about? Answering the original poster's question??
Yeah, I've used the "Patch" method a number of times for PAL --> NTSC. Doesn't work on all players though. Then there's the "Pulldown" method, which *is* reliable. I've even done a full-on conversion a few times.
But NTSC --> PAL?
Nah, back it up to make it region-free.
Pull! Bang! Darn! -
Good point gunsl1nger. If the original poster was to provide more details about what it is they are trying to convert it would be easier to recommend a solution.
Which is the opposite of the conversion in question.Originally Posted by ranosb
Most "PAL" TVs and DVD players, like mine, play NTSC natively.
I make DVDs with PAL menus, and a random mixture of PAL and NTSC features. Never had any issue (or flickering) playing them on my or my friend's systems.
Yes, it IS a waste of time to convert. All you need to do is strip out the region coding. -
Exactly.Originally Posted by AlanHK
Damn ranosb....you be gettin' b1tchslapped repeatedly.....
Im talkin about PAL to NTSC, too add to the discussion...It will flicker playin a PAL dvd on a NTSC system, period.
I have no idea about NTSC to PAL, which apearently looks fine from DVD players playing on a PAL system. -
Huh...Originally Posted by ranosb
Funny... i have never had that problem
And i have been playing PAL dvd's on my NTSC systems for years.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 20:52 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
