I am using DVDFab5, and I've been noticing that after i run it and the later delete the iles, there is still some very significant spae taken up on my hard drive, and I cant find any of it.
for instance. Tonight, i backed p two movies. I noticed that both of these movies ombined added 21 GB of data to my hard drive. When I deleted the video_ts files, there was still 7GB that remained.
Can this be explained somehow? Im going to back up another dvd tonight to see if the problem persists, but I'm pretty sure it will. Any ideas?
Probably working files left in a temp folder. Should be deleted when you reboot your computer, or you can do it manually
just do a search for *.* by date and say file size of 10,000kb
That should point you to them -
Empty the recycle Bin?
The electronic components of the power part adopted a lot of Rubycons.
Using DVDFab to copy DVDs to my Hard Drive a good place to start ?
By Bluelude1 in forum DVD RippingReplies: 29Last Post: 24th Nov 2011, 19:26 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
DVDFAB Platinum 6 . . . no process for saving an ISO to the hard drive? :(
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2009, 09:44 -
Hard drive mystery
By ranchhand in forum ComputerReplies: 9Last Post: 14th Nov 2007, 14:44
