I just got a Sony laptop with Vista OS. I want to create a partition to enable another volume. I’m having trouble going through in disk management and using command line. Apparently the hang up is pagefiles or snapshots are enabled in preventing a larger partion of the boot drive.
Does anyone know how to remove this? Thanks for your help.
TS
You may have to go with a third-party manager that works at boot time. I've used Paragon in the past and it has worked excellently. There are plenty of others, both free and paid, that you can check out. Search for "Hard drive manager vista" on Google.
Also, you can try this link if you want to stick with Vista's tools. -
Thanks for your help. I’ve already tried that method using command line, diskpart. exe; I’ve also tried Fdisk, along with Disk Management. Something is preventing creating a partition.Originally Posted by Supreme2k
I may have to resort to your suggestion of using 3rd party manager. All the advices make it seem so effortless to partition a brand new hard drive, but in reality as I read in different forums it’s not glitch free. I appreciate your help.
TS -
Believing yourself to be secure only takes one cracker to dispel your belief.
Lenovo Vista OS partition too small
By toolady in forum ComputerReplies: 4Last Post: 5th Jun 2011, 13:28 -
Installing Vista on a Sata hard drive
By xtreemman in forum ComputerReplies: 11Last Post: 31st Dec 2008, 16:48 -
vista will not reconize 2nd SATA hard drive
By steve42069 in forum ComputerReplies: 3Last Post: 20th Mar 2008, 12:58 -
Vista Basic - Hard drive is always busy
By edong in forum ComputerReplies: 39Last Post: 21st May 2007, 10:28 -
Modifying XP and Vista Partition Sizes on Single SATA Hard Drive
By Richkut in forum ComputerReplies: 1Last Post: 17th May 2007, 20:58
