We have a 12.3gb mkv file which plays fine on several software players. My question is how can I breakup this mkv file into smaller pieces(3 maybe) and put each piece onto dvd media and be able to play each piece on a stand alone dvd player?
Specs are: 1080p blueray dts x264.mkv
If you talking about a standard DVD player it's not going to happen. 1080p and x264.mkv are both deal breakers.and be able to play each piece on a stand alone dvd player
Convert to dvd and watch and buy a blu-ray player in the future and then author the mkv to 3 dvd as avchd with tsmuxergui.
Just to echo, conversion to DVD is your only option if you do not have a Blu-Ray player.
If you would like to play on your television, get a standalone. You can then use txmuxer and other tools (in the Tools section, to the left) to crate DVD-5 or DVD-9 blu-ray discs. Make sure that the player supports this feature (most that I've seen lately do).
Get a stand alone blu-ray player,i got a sony 350 which does a good job of playing avchd-dvd's.
johns0
Thanks for the tip. I was looking at the Sony 350 when I noticed the Sony 360 so I just ordered it.
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 11:56 -
merging mkv(h264) pieces, slight pause in-between?
By krv in forum EditingReplies: 4Last Post: 15th Nov 2010, 09:57 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
re encoding MKV files with subs to smaller file sizes with min qual. loss
By malakov08 in forum MacReplies: 1Last Post: 4th Apr 2009, 03:06 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 07:07
