to prevent 4gb avi splitting,
tools=>preferences=>output tab=> checkmark create opendml files
Results 31 to 40 of 40
Ok thanks i tried it. It gives me only one file of 63GB but the file is bugged. After 5 minutes of playing, it just stops.
Also, there is like a "lag" in the video (and it did it either with the 14 files and with the big file). Every 5 or 6 seconds, sound and video freeze for like 200ms. It is annoying. An idea?
I tried to convert directly from the mpeg-2 352x480 to mpeg-2 720x480, and it seemed to work just fine... Can you tell me exactly what's wrong with this version? -
I tried to convert in 720x480 and it worked and i did the authoring with "nero vison" because i own it but the rendering on the DVD player (after burning) is just "not good". When the camera moves, it is not smooth, i do npt understand.. can you give mu an advice to try please?
Well, on the computer it is just fine either before or after authoring.
But on the TV, the image is good when the camera do not moves. When the camera moves, as i said, it is a little bit blurred.
Maybe it is the way it should be... or maybe it is like that because of the snow... or maybe there is a filter to apply...
Also i have another question: can we apply a filter to a converted file? Because i cut and convert my .VRO file into an .MPG, and then i tried to apply a deinterlacing filter, but it did no difference between the original. -
i think that's just the low quality 352x480 mode of the camera. i would hope the high quality mode was better.
for dvd you should leave it interlaced. if it were going to be a computer streaming video then you might de-interlace. -
Ok thank you very much!
I think you resolved all my problems
I will record my final rushes, do the editing, authoring, joining etc... and i will let you know if everything went fine.
Thank you very much again, see you soon! -
Hello again!
I am pretty that you will think: "This guy is a pain in the ass...."
And you'll be right!
Before finalizing my project, i would have 2 general questions:
1) When i convert my .VRO 352x480 in .MPG 740x480, at the same time, i cut half of the scenes, but the final file size is 2GB (same as the original). Is it normal?
(Because i thought it would be smaller, with that size, all my cutted scenes, don't fit on one DVD. The excess is about 200Mb...)
2) When i do the authoring, do i need extra space on my DVD? Does the authoring take a lot of MB (a basic one i mean: 2 pages: 1 for the main title, 1 for the scenes selections)?
If yes i will have to cut more scenes, and it will be another problem...
Thank you for your answers.
PS: I am sorry but I am so far north and far from everything that I cannot get more DVD to do some testing, i have only 5 DVDs and no RW, i would like to do some tests but i can't i need to keep my DVDs for my final burning... So i am asking a lot of questions... I apologize for the inconvenience.
Mirror flip .mpeg before editing ! (Brevis problem)
By Hyacinthe Carle in forum EditingReplies: 7Last Post: 17th May 2011, 13:48 -
Good, easy avi editing program
By arnie22112000 in forum EditingReplies: 0Last Post: 2nd Aug 2009, 16:18 -
What is the Best/Easy to use Video Editing software?
By jbitakis in forum EditingReplies: 2Last Post: 16th Feb 2009, 11:13 -
Can Anyone suggest some REALLY REALLY basic easy editing software
By Jan29 in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 21:04 -
What is the problem with audacity? Can't do easy editing?
By happydog500 in forum AudioReplies: 10Last Post: 30th Sep 2007, 09:38
