I will be building a Media PC soon and was wondering whether it is still important have a separate sound card to record the audio to prevent any sync problems with the Audio & Video?
Most small motherboards seem to have sound and graphics onboard now; does this mean they are more reliable and less likely to cause any problems?
I realise that when editing it is important to use a separate sound card to record the audio rather than the onboard sound to prevent any sync problems. I currently use this method when capturing and editing on my main PC and it works perfectly. But as I want to build a small media PC just for recording TV I would like to use as smaller motherboard as possible so I was considering using the onboard sound.
Does anyone know whether using the onboard sound for recording is likely to cause any Audio / Video sync problems?
(Anything I want to keep will be transferred to my main PC for editing)
The sound cards/chips on most newer MBs are very good. Just a personal opinion, but I haven't used a PCI sound card in years. Don't really see the need for one. I have two MBs that have coaxial audio out and I plug that into my surround sound system. BD DTS audio sounds very good from my MB audio chip.
Probably my advice would be to try the on-board audio first, and if you have problems with it, then consider a add-on sound card.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
on board sound card
By m baqar in forum Authoring (VCD/SVCD)Replies: 2Last Post: 26th Mar 2008, 22:26
