I'm trying to burn mpeg 1 files with html files. The idea is to add interactivity when playing the vcd in a computer. I've gone as far as making the vcd using Nero but the burning program doesn't want to accept the html files when I add them to the mpeg files for burning.
Your inputs are most welcome on how it's best done.
<font size=-1>[ This Message was edited by: mannyger8 on 2001-07-23 21:16:51 ]</font>
You can add HTML files to the ISO filesystem on a VCD by simply dragging the files over in Nero (to the filesystem). You can also add additional files by using the XML system in VCDImager.
Remember, you have a limited character set to work with and are limited to the 8+3 file name format.
Regards.
Michael Tam
w: Morsels of Evidence
Adding Metadata to Video Files
By yardline in forum Video ConversionReplies: 8Last Post: 28th Oct 2012, 20:29 -
How do you make a simple html file showing list of files in a folder?
By yoda313 in forum ComputerReplies: 2Last Post: 6th Mar 2010, 20:12 -
How to Convert RAR HTML Files Into A Movie File
By raven120461 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 11:35 -
7z.html files???
By Glenn5782 in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2009, 04:43 -
free software for adding voice through mic to vcd
By andreytenov in forum EditingReplies: 4Last Post: 12th Nov 2007, 03:20
