Hi.
I have 2.38GB of MP3 files. I would like to put on a 700mb disc.
If this is possible. What would be the smallest audio format size could i convert to?
File size = bitrate * running time
So use lower bitrates. WMA and AAC sound a little better than MP3 at low bitrates. But unless all your files are very high bitrates to start with reencoding to low enough bitrates to put them all on a 700 CD will sound pretty bad. For example, reducing 320 kbps MP3 to ~80 kbps WMA might sound ok, but reducing 128 kbps MP3 to ~32 kbps WMA will sound like crap (you might find it acceptable for simple voice recordings). -
Are you using this for playback on a device or PC? or just archiving?
Beware many devices won't play back AAC or WMA and some won't even play MP3 on a CD
If for storage, why not use a DVD ?
As jagabo suggested, I wouldn't bother, because you are roughly reducing the bitrate/3 . So unless you are starting with 320kbps mp3, it's going to sound horrible. -
They will sound like complete garbage if you re-encode them from their already lossy status.Originally Posted by Teac23
Converting DVD's to best quality smallest size video file
By Thunderblaze in forum DVD RippingReplies: 1Last Post: 31st Dec 2011, 05:07 -
more video & audio channels in WMV file
By fixme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2010, 11:52 -
Coverting Video File to DVD without changing Aspect Ratio
By dwpoze in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 04:35 -
smallest file possible in DVD quality
By spiked4life in forum DVD RippingReplies: 6Last Post: 24th Feb 2009, 09:57 -
Video Stutter / Skip when coverting from DVD to VOB / MPEG2 file
By afs_nj in forum MacReplies: 2Last Post: 13th Jul 2007, 16:39
