I got a point here, that VISTA is good as compared to XP.
I'm having 512 MB RAM
I used to run some converters in XP, which utilizes 100% of CPU power.
then using some another application simultaneously was not possible or not that easy.![]()
But after that I installed VISTA, and got rid of this problem.
While using some converter I can easily use any other application simultaneously![]()
and also the PC configuration is same.![]()
Can anybody give me a satisfactory explanation, why ????
thnkx.![]()
AnonymousGuest
I don't suppose you could let us in on a few details? (What "converter" you're running, and what it's doing in each instance, perhaps?) Vista is not known for being more nimble than XP, particularly on a machine like the one you described.
Vista uses better memory management employing techniques such as Superfetch.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Vista usually just barely runs with 512MB RAM.
I use 2GB minimum for most of my Vista machines, and 4GB on the two newer ones. At idle, my Intel Quad shows 1GB in use.
But I do prefer Vista over XP. It might be bloatware/eye candy, but I like that.
W7 shows a lot of promise if MS doesn't muck it up.
If you have legacy software-it may not run on Vista. This also applies to hardware-though new drivers might be available for your device.
Vista to XP?
By vid83 in forum ComputerReplies: 36Last Post: 13th Feb 2009, 15:36 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 12:01 -
Vista or Xp
By negy in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 20:15 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33 -
Vista to XP?
By Xenogear900 in forum ComputerReplies: 10Last Post: 2nd Jul 2007, 21:49
