Hi.
I've managed to download the virtualdubmod program and can only seem to extract it using 7Zip.
Which file do I open in order to run the program?
RS
Results 1 to 11 of 11
Wow, you have the patience of a puppy. Double click on VirtualDub.exe in the folder you extracted to.
Buy My Books -
Right-ill just have a go.Please dont go away-thanks for helping brb
I have and it doesnt work.
It says " cant run program because corona.dll was not found.
Strange thing is is that there is a corona.dll file in the same folder.
Hmm..strange.
Please help. -
Try using the latest version of VirtualDub.
Buy My Books -
Try this
virtualdub_mod_setup.zipDonadagohvi (Cherokee for "Until we meet again") -
Hi-it's worked but something really odd has happened.Everytime I try to save the .avi(which was normally 3 GB),it saves it and runs out of memory because I find out that its been converted so far in 53 GB of data.
CAN SOMEONE PLEASE TELL ME WHATS GOING ON?!!!!
If you don't specify a codec to save with, VD defaults to RGB, which will give you huge files. Just select a appropriate codec.
Relax and take a deep breath. You are saving your files as uncompressed AVI. That takes a HUGE amount of space. Select a codec under Video - Compression to compress your resulting file.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Cannot run VOB2MPG after program crash
By coriakin in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Mar 2011, 02:36 -
Need help with VirtualDubMod
By Brakiri in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 05:28 -
HELP Please - Best Program for DVD to DivX/Xvid to run on 64bit win7
By Jorocketoz in forum DVD RippingReplies: 7Last Post: 4th Feb 2010, 05:39 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Trying to get an OLD program to run on a "newer" pc....
By Noahtuck in forum ComputerReplies: 13Last Post: 8th Aug 2009, 09:38
