Hi,
I was using Nero Recode 2.2.6.17c but it was very slow so i heard that there a new edition which is Nero Recode 4.2.16 (the one comes with Nero 9).
as can you see i start encoding the file
its pretty fast with also high quality
then come this error : :viannen_06:
& here is the log file Link
& here is the Gspot AnalysisCode:********** Nero Recode ********** Version: 4.2.16.100 Project type: Nero Digital Compilation name: My Disc Target size: Custom (51200) 08:52:58 File LangStreamPatcher.cpp, Line 56 Command table patching started... 08:52:58 File LangStreamPatcher.cpp, Line 129 All tables successfully patched! Burn settings: Target: Hard disk folder Number of copies: 1 Target folder: E:\Movies & Series (3111014400 bytes free) Shutdown when finished: false Advanced Analysis: false Compress Adaptive: false 08:52:59 File BurnNDigital.cpp, Line 259 NeroDigital: init 08:52:59 File BurnNDigital.cpp, Line 361 NeroDigital: burning 51200 sectors (51217 required) 08:52:59 File BurnNDigital.cpp, Line 400 NeroDigital: Adjusting target size 08:52:59 File BurnNDigital.cpp, Line 442 NeroDigital: beginning 1st-pass operation 08:52:59 File BurnNDigital.cpp, Line 976 NeroDigital: encode Scrubs.S08E16.HDTV.XviD-0TV 08:52:59 File BurnNDigital.cpp, Line 997 Nth-pass file = C:\Users\MAS\AppData\Local\Temp\\Scrubs.S08E16.HDTV.XviD-0TVa04820.bin 08:53:02 File BurnNDigital.cpp, Line 1166 NeroDigital: waiting for graph to complete 08:57:55 File BurnNDigital.cpp, Line 1247 received EC_ERRORABORT (-2147220945, 0) 08:57:58 File BurnNDigital.cpp, Line 850 An error occurred in DirectShow. It aborted for no good reason. 08:57:58 File BurnNDigital.cpp, Line 851 NeroDigital: compiling volume failed 08:57:58 File BurnNDigital.cpp, Line 299 NeroDigital: exit 08:57:58 File burner.cpp, Line 1796 An error occurred in DirectShow. It aborted for no good reason.
& about the codecs i installed on my system:
1-Vista Codec Pack 5.2.0
2-Combined Community Codec Pack
& any more info needed....let me know
thnx u all
You have codec packs and Nero, and wonder why it is failing ?
There is no place for codec packs on a sane person's machine, ever.
Nero is a poor encoder that has never been reliable. As a burner it lost me after 5.5.
You are also discussing downloaded material, which contravenes the forum rules - next time hide the names of your files.
Finally, you seem to be trying to crush the life out of over compressed source files. What are you intending to play such lower resolution, badly compressed files on ?Read my blog here.
sorry about the downloaded materials, i will change the pics asap.Originally Posted by guns1inger
do you recommend another encoder??
& about the codec pack, why shoud i remove them (i mean how could i play movies & other videos)??? -
Codec packs often contain outdated, mis configured and clashing setups. They rarely uninstall cleanly, leaving lots of crap in the system, and when something does inevitably go wrong, it is difficult to determine what and where because you have no idea what has been done to your PC.
Playback is simple - use VLC or The KM Player and you don't need to install many codecs at all. Otherwise use Mediainfo or g-spot to determine what codecs you need, and install just those codecs. At worst, install FFDShow, which is cleaner and smarter than a warez based codec pack (and let's face it, most codec packs are created for and promoted by warez sites because the people who visit said sites are invariable lazy and/or dumb). I have not used a codec pack in years (probably since my celeron 500 days when I was young and foolish), and there is nothing that I cannot play or convert.
As for encoders, try Xvid4PSP, which can convert most formats to most formats.Read my blog here.
No encoding options in XMedia Recode
By thezanny in forum Video ConversionReplies: 2Last Post: 26th Apr 2011, 07:02 -
Nero 10 Recode - Aspect Ratio problem?
By The.King in forum Video ConversionReplies: 6Last Post: 18th May 2010, 13:34 -
Nero 6 Recode problem
By Rad17 in forum Video ConversionReplies: 3Last Post: 29th Mar 2009, 14:43 -
Problem with Nero Recode
By mis3 in forum Authoring (DVD)Replies: 3Last Post: 26th Aug 2007, 00:30 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
