Alright, I reformatted my computer a few days ago and now I'm having problems encoding from an AAC source to anything else. I have the latest AVI Synth installed, VirtualDub, MeGUI, Lame, Winamp, Nero AAC, etc.
Basically I'm trying to encode the audio from a RAW anime source. When I say RAW I mean a captured video that's been encoded once. The problem happens when I try to use MeGUI to use the video's audio source (AAC) and encode it into either Lame MP3, Winamp AAC, or Nero AAC.
Here's the errors from MeGUI I get with Lame MP3, Winamp AAC, and Nero AAC respectively.
Nero AAC:
--[Error] An error occurred
---[NoImage] Exception message: The pipe has been ended.
---[NoImage] Stacktrace
----[NoImage] at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
----[NoImage] at System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count)
----[NoImage] at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count)
----[NoImage] at MeGUI.AviSynthAudioEncoder.encode()
---[NoImage] Inner exception: null
Winamp AAC:
---[NoImage] Exception message: Abnormal encoder termination -4
---[NoImage] Stacktrace: at MeGUI.AviSynthAudioEncoder.encode()
Lame MP3:
And when I try to convert it to WAV through Vdub with this script:
ffmpegsource("MyVideo.mp4", atrack=-1)
tfm(order=-1).tdecimate()
It only saves the first 6 minutes.
Anyone know why I'm getting these errors and can't encode from an AAC? If it's not an AAC I can encode it, I can even encode it into AAC if it's not an AAC source.
Results 1 to 1 of 1
Problem playback recorded .TS file AAC Audio
By paulc2002 in forum DVB / IPTVReplies: 2Last Post: 12th Feb 2011, 17:14 -
MeGUI, problem to encode audio from all AAC format(tape fast-forward sound)
By squall0833 in forum AudioReplies: 9Last Post: 13th Jun 2010, 14:54 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 01:03 -
AAC 5.1 to AAC 2ch conversion problem
By MR 3 in forum AudioReplies: 6Last Post: 2nd Feb 2010, 22:44 -
Problem using GraphEdit for AAC audio conversion
By Alterego in forum AudioReplies: 0Last Post: 21st Dec 2008, 12:41
