I don't know why every time I join two Xvid video clips using Avidemux (Video = copy, Audio = copy), the end result is always one Divx video, why is this?
Thanks.
What says it's a divx video? Maybe just the fourcc code is set to divx.
Hi Baldrick, both MPC HC (under properties) and Media Info are telling me it's Divx!
1) Xvid - clip 1
Format : AVI
File size : 91.1 MiB
Duration : 15mn 0s
Overall bit rate : 849 Kbps
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 15mn 0s
Bit rate : 646 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 1.500
Frame rate : 29.970 fps
Standard : NTSC
Resolution : 24 bits
Colorimetry : 4:2:0
2) Xvid - clip 2
Format : AVI
File size : 62.5 MiB
Duration : 11mn 30s
Overall bit rate : 759 Kbps
Video
Codec ID : XVID
Duration : 11mn 30s
Bit rate : 555 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Colorimetry : 4:2:0
3) End result Divx
Format : AVI
File size : 153 MiB
Duration : 26mn 30s
Overall bit rate : 810 Kbps
Video
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 26mn 30s
Bit rate : 606 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Colorimetry : 4:2:0
Scan type : Progressive -
It doesn't make a difference. DivX and XviD are essentially the same. The underlying video and audio should be the same, only the header metainfo is different if you used it correctly
You can change the fourcc with nic's fourcc changer if it makes you happy -
Wow, I didn't know that before and I just tried it and yes the end result is now XvidOriginally Posted by MysticE
Thanks MysticE, what's the difference between "packed" and "unpack"? and when Avidemux prompts me, am I supposed to "yes" unpack or "no" to unpack? All I want done is 2 Xvids in and 1 Xvid out
Thanks for the info poisondeathray
AviDemux Problem Joining Resized MP4
By thebigoc5 in forum EditingReplies: 0Last Post: 10th Aug 2010, 13:09 -
Avidemux for Splitting/Joining
By eskro in forum EditingReplies: 3Last Post: 29th Jan 2010, 11:44 -
Joining 2 different video clips without re-encoding one of them?
By Og in forum EditingReplies: 2Last Post: 7th Jan 2009, 01:54 -
Joining 3 AVI's. Having trouble with video sizes. AVIDEMUX
By UmmAddan in forum EditingReplies: 4Last Post: 27th Feb 2008, 23:03 -
two or more video clips (xvid) to DVD?
By kthan in forum Video ConversionReplies: 9Last Post: 3rd Aug 2007, 21:01
, why is this?
