I've got a DVD I'm ripping video off of but I'm not sure what codec to use. Mpeg-4 made the video choppy so I'm trying something else. Everything else I've tried has audio when I play it in Media Player Classic or Winamp but when I ad it to a project in FCE on my Mac it has no audio and it doesn't play audio in Quicktime either. What codec should I be using so that I get quality video and the Mac can play the audio?
Thanks,
-Jess-
What audio codec have you tried? I would use a dv-codec(like Cedocida DV Codec) for the video and uncompressed audio/lpcm wav for the audio.
Or use mpeg streamclip and convert the dvd vobs to mov files with some codec. -
I was using uncompressed audio.
I tried the Cedocida codec with uncompressed audio and I'm getting the following error:
Error: No audio decompressor could be found to decompress the source audio format.
I'll try mpeg streamclip as a last resort, it needs Quicktime codecs and I'm not big on downloading anything Quicktime related on to my PC unless it's absolutely necessary.
-Jess-
VirtualDub Capture Mod - Choppy Audio Playback?
By alinhoalisson in forum Capturing and VCRReplies: 11Last Post: 22nd Dec 2011, 12:34 -
Virtualdub Mod and Vobsub woes
By TheLaserdisc in forum Video ConversionReplies: 4Last Post: 30th Dec 2008, 00:03 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 13:59 -
Encoding audio with VirtualDub MOD
By GangstaRap in forum AudioReplies: 5Last Post: 19th May 2007, 07:20
