@madwh
Here you go.
Remove "Press Esc to ..." + Dual Screen Patch
File: NPSWF32.dll
Version: 10.1.102.64
Tested: No
MD5: F3D64D95B2668EED0C64BAEF43CED242
Results 91 to 120 of 518
Thanks for the new patchs CHRONOMASTER, they work just fine as usual (IE activex here).
See you,
TSR -
Hello folks, I am really excited to see this fix after so long. One of those situations where the majority suffer because some idiot somewhere got hijacked.
I would like to know if there is a way to remove the play and pause animations in flash in the center of the frame. If you are pausing to read, they're spectacularly distracting. They only appear when using the space bar to pause or clicking the frame.
Hunter -
About that? Some malware uses full screen representations of a system in flash to get people to do things. Of course, it won't work right, because flash has some limits, but some people just can't control themselves. You want a link for that? I don't know if Adobe has a page on it...but any way...
I'm talking about this...
I want to pause the frame to look at it (read) but that thing in the middle pops up. -
Link of the clip?
In the new 10.2 beta (10.2 d151 / 10,2,151,49) the dual screen bug is fixed. But now I again need a fix for the "Press Esc.." annoyance.
Can anyone help this time around? Please. -
Its beta version, probably next week will be new beta version.
The pause animation length like half second and disappear,
if click on pause button on bottom the pause animation not appears
And Its not related to Flash plugin, its related to SWF flash object video player on youtube site
If take look for example on other video streaming sites like: www.dailymotion.com www.metacafe.com www.atom.com
They have different pause animation, because they have different SWF flash object video player.
Hi, Chrome auto-updated my Flash version to 10.1.103.20
Any chance for an update to this? -
Does anyone know if it's possible to use this hack in os x somehow or is there an os x version of his hack?
I have successfully hacked the latest Windows version of Flash (10,1,103,20) for Chrome (8.0.552.237)
I followed the instructions here to remove the Press Escape message, then applied DrizzlyChrome to fix the dual-monitor focus issue.
Was actually pretty easy. Attaching here to share with all other Chrome users. -
Hi all,
Latest Flash is 10.1.103.22 for Google Chrome (9.0.597.84)
Here is the hacked version (press escape and dual screen fix). -
Are you using the latest video drivers roma? (nvidia 266.58, Ati dunno..)
10.2.152.26 seem to be working OK here. -
Can anyone remove ESC info from latest NPSWF32.dll & Flash10l.ocx on v.10.2.152.26?
How do I patch to version 10.2 for Firefox? I guess I have to replace NPSWF32.dll, but I can't find it on my computer.
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 05:33 -
Remove green/purple "bloom" from video
By mikeveli20 in forum RestorationReplies: 4Last Post: 3rd Oct 2011, 15:08 -
Is there a way to remove or cover the "bug" in a video?
By HuffmanFamilyof4 in forum Newbie / General discussionsReplies: 5Last Post: 24th Apr 2011, 21:57 -
Gray "!" iTunes 8 annoying song location issue...
By Nintendo Fan in forum ComputerReplies: 12Last Post: 14th Jun 2009, 10:38 -
Philips DVP 3140: Annoying black bar after pressing "play"
By tt-jones in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Sep 2007, 22:29
