Ok
pepflashplayer3 2_23_0_0_207.dll file need to select
when you click on Other button in flash fullscreen patcher
Results 481 to 510 of 518
i have an idea. can you patch pepflashplayer3 2_23_0_0_207.dll and upload it for me so i can just replace mine with yours?
does the patch work with Microsoft edge? could you please upload patched npapi Version 24.0.0.194 for opera?
Probably yes, if Edge using same flash plugin as Internet Explorer
cannot test this because in my computer Edge don't display flash for some reason
Version 24.0.0.194: https://mega.nz/#!Y1hDQbjY!KtZGSFCpcWlSZ-EW7O6IRfQkyYnUJ7OYZ9XQlmfkATo -
both 32 and 64 don't work on opera latest version. only this one work pepflashplayer3 2_23_0_0_207.dll
i shouldn't update flash at all. are you sure that 64 version is for opera?Last edited by model; 31st Jan 2017 at 21:56.
I checked everything is working
pepflashplayer32_24_0_0_194.dll need to copy to C:\Windows\SysWOW64\Macromed\Flash
pepflashplayer64_24_0_0_194.dll need to copy to C:\Windows\System32\Macromed\Flash -
my man I install win 8.1 with ie11 that has flash pre installed and your patch doesn't work. it can patch 64 but doesn't work, it can't patch 32 so I manually put your patch (select no since it can't patch 32) new flash.ocx in C:\Windows\system32\Macromed\Flash
it doesn't work too. please advise -
Try download from link 32bit and copy to folder C:\Windows\system32\Macromed\Flash
https://mega.nz/#!NgQHWAzD!7aql38xg7wAP1PjFFlv5PcHkvgVTbhUSeoUy6dBX5r8 -
nvm i give up, could you please post flash version 24.0.0.221 for opera? i only use opera anyway.
Try follow steps in attached video to patch flash for Opera 32bit
thanks a lot. do you know where microsoft edge flash folder is? i'm going to try your video manual on edge. i don't even know how to update flash if it's built-in. with edge, i'm stuck at 24.0.0.194, can't watch any twitter videos.
does it work with other browsers that have built-in flash like epic browser? (the one that has proxy like opera) -
Flash in Edge don't work on my computer
try follow steps in attached video to patch flash for Epic Privacy Browser -
i know that step, it's just that i use windows 7. when i click other button, nothing happens so i can't select pepperflash from desktop. it works on windows 10 though. please give me this flash version and i won't ask you again.
https://mega.nz/#!RtxkECrT!SbDoq03L6JZVCMqZ2gAQ9Y1rETLkaSQPhBPEwvNn6qo
don't forget copy to right folder
thank you sir. i remember the right folder you told me.. i'm sorry i have to ask you to upload so many times. maybe i should install windows 10 which i hate. do you have something installed from microsoft like .net, c++ that makes 'other' button works on windows 7 vanilla (no sp1 because it will silently download windows 10 on my hard disk) ?
p.s. do you somehow figure out how to make it works on microsoft edge? -
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 06:33 -
Remove green/purple "bloom" from video
By mikeveli20 in forum RestorationReplies: 4Last Post: 3rd Oct 2011, 16:08 -
Is there a way to remove or cover the "bug" in a video?
By HuffmanFamilyof4 in forum Newbie / General discussionsReplies: 5Last Post: 24th Apr 2011, 22:57 -
Gray "!" iTunes 8 annoying song location issue...
By Nintendo Fan in forum ComputerReplies: 12Last Post: 14th Jun 2009, 11:38 -
Philips DVP 3140: Annoying black bar after pressing "play"
By tt-jones in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Sep 2007, 23:29
