Page 16 of 18
FirstFirst ... 6 14 15 16 17 18 LastLast
Results 451 to 480 of 518
  1. The link isn't working anymore. A Dropbox page opens with a message saying Restricted Content and that the file is no longer available.
  2. Originally Posted by Bruce Wayne View Post
    Thanks for reporting
    I fixed the link
    for some reason Dropbox changed path link
  3. Originally Posted by roma_turok View Post
    I fixed the link
    Cheers.
    EDIT: Nope, sorry, it's not working. I still get Restricted Content, file no longer available.
  4. Originally Posted by roma_turok View Post
    OK
    some automatic crap on Dropbox
    changed to Mega
    Thanks. Got it now but it's not working properly, unfortunately. Works fine in Firefox but not in Chrome or Opera. In Chrome, I still get "Press Esc to exit full screen", and in Opera, "This page is now full screen. Press F11 to exit."
  5. From my testing
    Its still remove message on FLASH VIDEO, on all web browsers
    the majority websites now switching to HTML5 video player
    so probably the message you see, its from HTML5 player
    for Opera you probably need patch manually:
    Close all web browsers windows
    click on Other button and select all files one by one
    with file name starting with pepflashplayer
    To check go to this link for example: http://livestream.com/watch/browse/animals
    on right click on video you can check if its Flash player or HTML5:
  6. Originally Posted by roma_turok View Post
    From my testing
    [Attachment 36443 - Click to enlarge]
    Thanks for the info. I hadn't understood it only applied to Flash. I won't need to be doing any fixes to any other browsers though. I've decided just to stick with Firefox.
    Dec 2009
    Netherlands
    In Chrome 49 with flash: 21.0.0.216 it doesn't work anymore.
    Update: de pepflashplayer.dll is now under: C:\Users\{user name}\AppData\Local\Google\Chrome\User Data\PepperFlash\{LATEST VERSION}\
    After patching this one everything works fine again
  8. please support for RTVE.ES
    is documentary channel english, frances & german with audio spanish, the last time at 2015 november working mode flash. now is html5 player and is very shit and slow. im sorry for my lang. long long time a go that i no speaking.
    please u roma turok, you will always my hero that brough solution with this great patch. Thanks.
  9. Download of v3.0 still gives Restricted message...
  10. Originally Posted by jonathancr View Post
    I not created the patch
    and you cannot force website use flash with patch
  11. Originally Posted by 30west View Post
    in flash video?
    you have link example?
  12. Its link from CHRONOMASTER post, that I cannot change
    but you can download from my first post
  13. Thank you..
  14. Just installed - patch doesn't seem to work with FF 46.0.1 and Flash 21.0.0.213
  15. From my test its working
    I have firefox 46.0.1 and flash 21.0.0.213
    did you test this on flash video?
  16. Hmmm .. I tested it after restarting FF and didn't work. Restarted FF again and now it's working on all the sites I've tested. Bizarre..
    Thanks...
  17. Originally Posted by roma_turok View Post
    thanks for you opinion romaturok, always well received.
    others points
    i see an chrome extension called "switchhero redirector" that is for help to replace spam links banners to blanks links inside videos.
    many times ADBLOCK can not lock iframes div inside webplayers.
    perhaps this extension can serve as: Disable Youtube™ HTML5 Player
    redirecting html5 that YouTube assigned to old flash mode.
    in vaughnlive has served for blocked sponsors, banners, buy plus emoticons in middle of screen player.
  18. now youtube has proposed new modality with animations and effects transitions delays fade in fade out.
    an shit
    ¿how to remove this delay lag animations?
    example in link
    http://www.tympanus.net/PausePlay/
  19. Do you mean effects transitions fade in
    when its going to fullscreen?
  20. play and pause
    the transition effect is combined when clicking mouse
    fade in [+300/mls]
    fade out [+300/mls]
    new modality made for touch dispositives & moviles.
    seem to want to to forget the mouse users.
  21. Sorry
    but the animations part of website and cannot be changed
  22. works on chrome, doesn't work on opera. click other as you suggested, nothing shows up so i can't select any files.
  23. If you using Opera 64bit on Windows 64bit with Flash version 23,0,0,207
    Opera using file pepflashplayer32_23_0_0_207.dll
    in folder C:\Windows\SysWOW64\Macromed\Flash\
    click "Other" copy and paste in "File name": C:\Windows\SysWOW64\Macromed\Flash\pepflashplayer3 2_23_0_0_207.dll
    click Open
  24. i don't understand a word you said. i told you when i clicked other, nothing happened and you use process monitor, not the flash fullscreen patcher.
    what's it with copy&paste? open it with flash fullscreen patcher? then copy&paste it where? the file already exists, do you mean make a backup of pepflashplayer3 and open it with flash fullscreen patcher to patch it?
  25. 1) Open flash fullscreen patcher
    2) click "Other"button
    3) copy&paste to "File name": C:\Windows\SysWOW64\Macromed\Flash\pepflashplayer3 2_23_0_0_207.dll
    4)
    click Open
  26. why don't you show me the picture when you click the 'other' button.
  27. i don't. it doesn't work, is it? no. 2 copy&paste to... copy&paste what?
