alright... I give... Must be my serious learning defiency that's causing this problem...
Captured as a sample the local soccer game on tape. Fed it into the computer and now have a wonderful avi file.
The file stats say:
720x480
bitrate 1024
audiosample rate 16bit
framerate 29fps
video sample size 24bit
DV Codec
Now I am trying to convert it into a BEAUTIFUL MPEG2 file with TMPGenc using the following settings:
Video Stream Mpeg2
720x480
Aspect 4:3 ???
frame rate 29,97
Rate control mode CBR???
bitrate 1150???
Profile level: Main Profile
Video Format NTSC
Interlace
4:2:0
DC component Precision 8 bits
Motion search precision Highest quality
When using this setting the video come out perfect EXCEPT when ANYTHING moves...
Example would be a soccer player running... the edges around the player would look all blured and fuzzy....
It can not be this hard to convert a stinking DV movie into Mpeg 2 to burn it to a vcd/svcd/dvd... or is it...?
What am I missing...??? Doing wrong...?
How can I keep the quality at least above VHS and be proud to show it to the grandparents etc... My baby needs to be shared in DVD format with the family etc... <Grin> Please help...!
Thanks for all of your help ahead of time... I really DO appreciate it...
Scholty
:oops: Sorry, but I would like to bump this...
It's been a week and still no luck...
I am thankful for any help I could get...
Scholty -
scholty,
There are tons of different settings that people use when converting to mpeg2. I would start with the default SVCD template (load SuperVideoCD) which uses a much higher bitrate, and formats to 480x480.
Those crazy edges you are seeing are from a combination of way too low bitrate, and interleaving (interlace). The SVCD template uses the best settings for DV which are interleaved source -> interleaved output.
If for some reason you can't use SVCD, then use the VCD template, unlock it, bump the bitrate to 2000, and under the Settings - > Advanced tab, double-click Deinterlace. Try the different methods and see which one looks best to you. They are all a compromise and the SVCD is still the best way to go.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
MPEG2-->MPEG2 Crop + Resize
By wincrazy in forum Newbie / General discussionsReplies: 26Last Post: 24th Jan 2009, 01:30 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
