put a thump thump stereo on it...........and an umbrella, wet bar, and sidecar
Results 31 to 40 of 40
Been using a craftsman riding mower for the last few years,cuts an acre lawn in 30 min.
yes.it makes life easy
specially during hot and humid weather .plus I chose this mower because it's made by Husqvarna .
I'm thing about replacing the OEM blades with this one,but lifting this beast isn't ganna be fun .
I should contact Pimp My Ride for help
You may not have to lift the mower. Most decks today are made to be very easy to remove. They are usualy held on with 4 quick release pins.
Mulching blade? Hmmm, right up my alley... I have a 20yr (yes, 20) rider that I got free from my FIL about 5-6 years ago. The only thing I'd like to do is put a mulching blade on it. I'm not a gear head so I wasn't looking forward to getting that thing up to replace the blade. Actually, I haven't even sharpened the thing that's on there since I got it.Originally Posted by MJAHave a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
blades are cheap.2 for $34 only.my only issue is lifting the mower .deck doesn't have an easy release pins.
use a couple of small jacks or even car ramps...Good luck
Are you sure? What's the pin in front of the rear tire? In the pic it looks like one of the pins you would pull so you can slide the deck out.Originally Posted by MJA
If your deck doesn't come out easy and you want to lift the mower you could go with this. http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_1619...g=true&cFlag=1
Rip Riding Giants
By WOTS in forum DVD RippingReplies: 2Last Post: 12th Sep 2011, 22:14
