OK, so i got a slow pc. I realized i get a lot less frames dropped wehn capturing at 15 fps. Is this possible to change it to 29.9 using tmpgenc? Any information i should know? Quality loss?
Well sure you can the encoder will just encode every frame twice.
The results wont playback all that smooth so quality takes a big hit.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
FLVs and 15fps?
By CursedLemon in forum Video ConversionReplies: 4Last Post: 10th Oct 2009, 18:30 -
Importing 15fps (320x240) footage into Premiere CS3
By Alain2007 in forum EditingReplies: 3Last Post: 4th Feb 2008, 00:30 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 10:42
