I'm thinking of getting an HD camera that uses the h.264 codec. I am just starting to get a grip on this thing and could use some advice.
I have a P4 3.4G Windows XP computer with a pretty decent, albeit older AGP graphics card. I use Premiere Pro and Sony Vegas 7 editing software with a TMPGEnc and CinemaCraft encoders. Is this computer going to be able to handle the editing chores for this codec? How about encoding for DVD and the web?
If anyone can give me a quick rundown on this, I would really appreciate it.
Is the camcorder AVCHD or some other flavor of h.264?
To edit AVCHD natively you will probably need to upgrade Vegas and buy a new PureVideo HD PCIe video card for playback. It would still be sluggish.
Or, spend $129 on the Cineform Neo Scene digital intermediate codec which will recode AVCHD or HDV into a GOPless 10bit 4:2:2 intermediate that can be edited in your current hardware and software.
http://www.cineform.com/neoscene/features.phpRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for that info. I'll check it out.
The camera is a POV cam, so there won't be a lot of complicated editing being done. At first it will be used for internet video clips. As long as I can get the video into a codec my current gear can handle, that would be great. -
Better ask Cineform about the POV cam. They have a good support line.
It looks to me like the POV is a standard def cam. If so, your current hardware may support a full decompression without the intermediate codec. In that case you would need a 2 disk RAID zero to handle uncompressed 720x480.Recommends: Kiva.org - Loans that change lives.
Here's the camera:
http://www.vholdr.com/contourhd/overview -
That camcorder can record 1280x720p @30fps or 848x480p @60fps (wide square pixel SD). 30fps will require stabilization (solid tripod or steadicam etc.). For action and hand/head mount the 848x480p @60fps looks more attractive. Pixels per second slightly favor the SD mode as well (814k vs 922k pixels per 1/30th sec) allowing less compression.Originally Posted by Ron B
The recording codec is an unspecified h.264 (not AVCHD) at ~8Mb/s to 16Mb/s. Audio is AAC. AVS "Easy Edit" software is included.
http://www.avs4you.com/AVS-Video-Editor.aspx?type=GoogleAdWordsSearch&gclid=COWehvG-mZ...FQwxawodIwcN8A
You will need to experiment with import or conversion to make it work with Vegas 7. Direct playback will probably be a challenge on your hardware. For this reason conversion to an intermediate may be the better solution. See if the Neo Scene demo works with this format. Experiment.Recommends: Kiva.org - Loans that change lives.
[quote="edDV"]
oh my god.Originally Posted by Ron B
i dont know easy edit but i had a "pleasure" to use AVS player for avchd/h.264. their codec is a total crap.
cant find worse codec. if edit software has similar performance then it is probably useless.
i would not buy this very camcorder because of the software :/
edit: sorry, i just noticed that this is helmet camera and it is pure fun
i could buy it even with crappy software (this is something you can always change)
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Are there different versions of the MainConcept H.264 Video codec ?
By Bansaw in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 11:00 -
Where to get Functional h.264 codec
By thunderpanda in forum Video ConversionReplies: 6Last Post: 25th Dec 2011, 23:07 -
MSU MPEG-4 AVC/H.264 2011 Video Codec Comparison - CALL FOR CODECS
By DmitriyK in forum Latest Video NewsReplies: 1Last Post: 28th Jan 2011, 15:27 -
can't encode using H.264 codec
By arabian in forum Video ConversionReplies: 6Last Post: 28th Sep 2007, 18:44
