When i play SVCDs on my Universum DVD-Player it shows the Video fine, but i could not hear any Audio!! It says "Audio unbekannt" = "not known Audio".
VCDs works fine with Video and Sound, only SVCDs don't work!!
Do someone know why??? MPEG-Files? Burning Method?
I burn with the newest Nero-BurningRom with SVCD PlugIn.
got the same prob
looks like the player does not play SVCD .mpeg sound, which is just annoying and tells me I bought the wrong &"%!$§ DVD player -
I suggest you look through the audio settings on your DVD player and see if somewhere there is a "PCM" setting. If so, try that.
well, that was the first thing I did ... i switched from bit stream to PCM, but nothing happened
I multiplexed the MPEG2 Program (VBR) to MEPG2 SVCD (VBR), now Ulead Movie Fac. tells me the .mpg is a valid file for burning to SVCD - I burned it, tried it - no sound. I'm really cooking now.
VCD working fine, and as of VCD has PCM just like SVCD the player should play it. I'm nearly giving it up ...
Would the VCD header trick help in this case? Will try this then ...
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 20:25 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 13:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 22:44 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 17:02
