Results 1 to 9 of 9
    Mar 2009
    Hello,
    I looked everywhere on here before i posted and found some answers but not exactly what I was looking for.
    I haven't purchased a PS3 yet and this may be the deciding factor.
    I have a bunch of avi movies on my mac.
    When i convert them to dvd it doesnt always work the way i want.
    If i put them on to a dvd+r unconverted (keep as avi) and pop the dvd+r into the PS3, will the PS3 play them.
    Sorry if this is in the wrong forum, but I searched on here for a while.
    Apr 2004
    Miskatonic U
    AVI is just a container. How the movie is compressed - which codec was used - determines what can play them back. If they are Xvid/Divx then most likely they will. You need to provide more detail about the files to get a more definitive answer. If this is the case, a cheaper solution is a $60 Philips Divx capable DVD player.
    Read my blog here.
  3. PS3 supports Divx/AVI. But AVI is a container and can contain audio and video encoded with many different codecs.
    Mar 2009
    Thank you all, i'm new to all this video stuff.
    I'm trying to study the glossary and types of files.
    I'll look through some of the avi files and see.
    Thanks again
  5. Use tools like MediaInfo and GSpot to identify container types and codecs.
    Mar 2009
    thanks for the links. if the avi's aren't the right codecs can i convert them to the right codecs?
  7. Originally Posted by pmmassacre
    Yes, you can use programs like AVIRecomp (very easy), VirtualDub (takes a little learning), etc.
    Mar 2009
    Wow, thanks alot man...really appreciate the help
  9. Glad to help out.
