Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Dec 2008
    Hey all,
    I have downloaded a set of MKV H.264 files which have two audio tracks (1. German 2. English)
    I wish to, eaisly, batch process all the files (hundreads) and remove the first audio track from the container.
    Is this possible?
    Cheers,
    iBeech
    I would use mkvtoolnix and use the command line version and then make a bat file with a for loop. I will see if I can make an example.
    Dec 2008
    cheers Baldrick- your help is much appreciated.
    THis will ONLY work if all mkvs are similar with 2 audio tracks and 1 video tracks,
    Install mkvtoolnix. Run mkvmerge gui, open one mkv, disable the german audio track, click copy to clipboard, open notepad and paste it and you will get something like
    "mkvmerge" -o "E:\\Temp\\video2.mkv"  "--forced-track" "2:no" "--language" "3:eng" "--default-track" "3:yes" "--forced-track" "3:no" "--display-dimensions" "3:16x9" "-a" "2" "-d" "3" "-S" "E:\\Temp\\video.mkv" "--track-order" "0:2,0:3"
    and then add for %%a in ("*.mkv") do and replace -o "E:\\Temp\\video2.mkv" with -o "%%a-newvideo.mkv" and -S" "E:\\Temp\\video.mkv" with "-S" "%%a". This will make a NEW mkv for each named like oldmkvname.mkv-newvideo.mkv. Example:
    for %%a in ("*.mkv") do "mkvmerge" -o "%%a-newvideo.mkv"  "--forced-track" "2:no" "--language" "3:eng" "--default-track" "3:yes" "--forced-track" "3:no" "--display-dimensions" "3:16x9" "-a" "2" "-d" "3" "-S" "%%a" "--track-order" "0:2,0:3"
    Save it as video.bat in the mkv folder(be sure to choose save as and choose save as file type: All in Notepad)
    Then run the video.bat...or run it from the command line(start->run->cmd) and cd c:\folderwithmkvs and type video.bat and you will see if you get any errors.
    If the mkvs are not similar then you have to fix each manually, open in mkvmerge gui, disable track, add to queue, repeat, start muxing.
    Dec 2008
    I really appreciate your effort in this! Yes, all MKVs are identical in this manor so it should work!
    Thanks and i'll keep you updated
