Which one is the best... I can't really find info on each of the different avi format settings. If possible can someone tell me which one is best for quality.
And on another note, is increasing size for 2 pass size (230mb) for a file that's 175mb a good choice? Or should I just go with 1 pass extreme encode (constant quality, and what does the number tell... default being 3).
- and avi can be a container for x264...? I just noticed that right now...
- q16-q21, which is best?
Which is best ? Mmmm. How long is a piece of string ?
What is your source ?
What do you want to do with the file ? Standalone playback ? WD TV ? Different requirements for each.
Without knowing what you have and where you want to go, it is impossible to give you a recommendation.
Personally, I would not put H264 inside an AVI container. Standalones won't play it, and many software players will have problems. Leave H264 for MP4 or MKV files instead. If you are encoding H263, the smaller the Q value, the higher the quality and the larger the file.Read my blog here.
It's a avi/xvid source. Just keeping it in pc, but might cut the avi and append it later on depending on my preference in the future. What's a WD? Well I'm not trying to re-encode it for tv use. I'm just making a little change in resolution (it's a 4:3), not trying to make it 720p or anything. So would that extra size be of any benefit for the 2 pass size encoding?
Edit: Oh and thanks for the response.
I've tried the 1 pass extreme xvid and it came out smaller than the original (in size).
And what's AVI DV PAL/Miezu used for? (size seems to get huge when i change it to those.) -
Post a media info of the file, and a screen shot if possible. You might be making this much harder than it needs to be.
DV AVI is the same as recorded by Mini-DV cameras. 13 GB/hour footage space requirements. Ideal format for editing.Read my blog here.
mkv to avi with xvid4psp! It's killing me! Help pls!
By Ramazan in forum Video ConversionReplies: 1Last Post: 28th Sep 2011, 08:52 -
Need Help on XviD4PSP (Conversion of MKV to AVI, subtitles SPU codec)
By gallen16 in forum Video ConversionReplies: 3Last Post: 10th Oct 2010, 11:44 -
Xvid4psp 5.0 problem converting .mkv to .avi with subtitle
By Conrad007 in forum Video ConversionReplies: 3Last Post: 13th Jan 2010, 15:15 -
How to convert a DVD to a NORMAL AVI file using XviD4PSP?
By coxanhvn in forum DVD RippingReplies: 3Last Post: 8th Jan 2009, 16:31 -
Error with MKV -> AVI with XviD4PSP
By Born4battle in forum Video ConversionReplies: 1Last Post: 9th Nov 2008, 15:39
