    Mar 2009
    Hello guys.
    I heard for burning 2 copies at once of a CD or a DVD I should use ALCOHOL 120%. Where do I buy it? I want to pay for it and get the actual software disk.
    Thank you
    orfa
    canada
    Imgburn will do the same and is free.If you really want to buy it just click on the link you made.Also when you burn 2 discs at the same same it will slow down both burners to the point where burning one at a time is just as fast and more reliable,no need to search for burning software on more threads cause its a waste of time.
    Mar 2009
    You are so sweet, thank you.
    Can you please tell me where on ImgBurn there is a place to select "Multiple Burners"?
    Orfa
    canada
    Just run another instance of imgburn and change to your other burner.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You can get Alcohol from their website.
    http://www.alcohol-soft.com/
    Google is your Friend
