What is a good script to work with my? I don't know how to upload a clip. I am re-encoding my XviD to DivX. I like DivX better. I haven't noticed any quality lost. I will post my results below from MediaInfo. I'm also resizing to 640x360 for 16:9 and 640x480 for 4:3. I am using LanczosResize. I am also curious what scripts does DivX corp use?
General
Complete name : D:\Movies\The Breakfast Club\The Breakfast Club.avi
Format : AVI
File size : 698 MiB
Duration : 1h 37mn
Overall bit rate : 1 006 Kbps
Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library : VirtualDubMod build 2178/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 37mn
Bit rate : 871 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.161
Stream size : 604 MiB (87%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 88.8 MiB (13%)
Alignment : Aligned on interleaves
Interleave, duration : 83 ms (2.00 video frames)
Interleave, preload duration : 504 ms
Writing library : LAME3.97
Encoding settings : -m j -V 4 -q 2 -lowpass 17 -b 128
Language : English
You gain nothing at all by encoding a perfectly good Xvid file to Divx. In fact, you risk reducing the quality by needlessly recompressing and already heavily compressed video.
If you must convert your files to Divx, re-rip your original DVD, and use AutoGK to do the encoding for you.Read my blog here.
Originally Posted by guns1inger
You won't post up scripts that works good? -
as already pointed out xvid > divx is pointless. The info you posted conforms to divx ht spec .... change the ffourcc if it makes you feel better.
To Script or Not To Script, that is the Question... (Custom Videos)
By TheMcD in forum EditingReplies: 2Last Post: 21st Oct 2010, 10:11 -
Any good tv script sites online?
By yoda313 in forum Off topicReplies: 4Last Post: 24th Jan 2010, 09:29 -
WMA with markers & script does not work in Windows Media Player 11
By musomn in forum AudioReplies: 0Last Post: 16th Oct 2009, 09:24 -
Online video converter script
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 15th Apr 2009, 05:26 -
Video Conversion Script
By paug in forum Video Streaming DownloadingReplies: 1Last Post: 16th Oct 2008, 02:49
