I need some help in jumping titlesets. I'm making a DVD in which there are some 16:9 content and 4:3. I know that I can only apply what aspect to an entire title set so I created a second one for the other aspect. The problem is that I want the DVD to loop so Each title calls the next and at the end the last calls the first-which worked until I had two title sets. Now the last calls the first of that title set only.
I've tried writing in the command by hand of jump titleset 1 title 1; in the post command portion of the last video in the second title set and the player just stops. I can set buttons to jump to different titles in title sets just fine!
How should I do this? I don't have any vMenus just the menus that are created when you first start a project and create a second titleset.
I got tired of looking for answers and I think I read something that stated that if jump pads are on (which they are) then this is not allowed, bummer.
What I did instead is took an AVS script and fed it to henc to pillar box the video into 16x9 since most of the content was. Removed the title set and kept it as a simple one menu one title set disc that will loop forever.
The only reason this was needed is because the videos will be marked as being 16x9 and 4x3 will be stretched when played, the only down side is the 4x3 materiel will be booth pillar and letter boxed on 4x3 screens. -
Have you tried using pan-and-scan for the re-encoded 4:3 video? IFOEdit may be of use to you for that. See https://www.videohelp.com/forum/archive/4-3-digital-tv-capture-pillarboxed-in-16-9-ifoe...g-t255872.html
I didn't know about that but I'll check it out for next time. This project is going into use tonight and should be fine as is. Thanks for the information.
DvdStyler: multiple sets of menu buttons
By skaleton in forum Authoring (DVD)Replies: 16Last Post: 22nd Aug 2015, 05:09 -
Multiple title-sets share the same vob's
By kdolan1973 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 17th Oct 2010, 19:52 -
title sets running slow
By l0rdinfamousxx in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 12th Feb 2009, 07:07 -
Question about auto jump to next title with Gui For DVDAuthor
By jimdagys in forum Authoring (DVD)Replies: 6Last Post: 26th Nov 2008, 03:55 -
Panasonic DMR-EA18K - Title Jump
By pannayar in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Aug 2008, 00:56
