Hi all,
I downloaded a video that says it's in rmvb format, but it wasn't playable. I checked it with GSpot and both the audio and video codecs appear to be for a WMV movie.
Audio codec is 0x0161 (WMA v2)
Vid codec is WMV2.
What can I do to fix this?
Thank you
Under container, it says:
File Type: ASF [WMA/WMV]
MIME Type: video/x-ms-asf
I tried to change the extension by right clicking on the file and choosing rename, but that didn't work.
How else can I change the extension? -
You need to go to 'Folder Options' in 'Control Panel', and under 'View', uncheck the box for ' Hide extensions for known file types.' Then you should be able to change it.
Thanks! That worked.
But the video still can't play. Window Media Player says something about DRM... had no idea.
I give up.
Delete.
There's a lot of 'fake' WMV files on the net. Many of them are a scam, they want you to log into their site to get the password/DRM key. (And likely a few trojans or a virus or keylogger to go along with it.) Sometimes a ad will pop up.
If VLC won't play it, trash it. VLC doesn't much care what the extension is, it just reads the file and most times uses the correct codec. If you see a green blotchy background and no picture, it's probably DRM protected.
Gspot cant determine codec?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 06:14 -
Sequence Display Extension in GSpot
By sambat in forum Authoring (DVD)Replies: 5Last Post: 8th Jun 2010, 06:41 -
rmeditor unsupported codec, how to cut rmvb ?
By kclgad in forum EditingReplies: 3Last Post: 7th Apr 2009, 07:38 -
Which codec do I need from this GSpot pix?
By tigerb in forum Newbie / General discussionsReplies: 9Last Post: 1st Nov 2008, 08:11 -
AC-3 ACM Codec na RMVB = PROBLEM
By krain_l in forum Authoring (DVD)Replies: 1Last Post: 16th Jun 2007, 18:48
