How do you burn vob files with imgburn like both folders VIDEO_TS & AUDIO_TS have to be on a DVD to-gether
Seriously??? After 4 years here, you don't know how to use imgburn, the guides, or links?
Open imgburn, select the folders, then burn. It couldn't be any simpler. -
Use the Ez mode, 'Write files/folders to disc' and select your VIDEO_TS folder. Or the manual 'Build' mode does the same thing. If you don't have a AUDIO_TS folder, ImgBurn can create a empty one. It isn't used for much of anything at present and it's optional. All of the DVD is in the VIDEO_TS folder.
You can also go to the ImgBurn site, but the guides will tell you about the same as above. It's hard to mess up. ImgBurn will tell you if you do.
Pick write folder to disc, browse to the folder and pick the Video_ts folder (ignore the audio_ts folder) click burn. it's that easy.
I love children, girl children... about 16-40
W.C. Fields
Problem since upgrading Imageburn to 2.4.4.0
By jfreytag in forum Authoring (Blu-ray)Replies: 12Last Post: 14th May 2009, 19:07 -
How to create a DVD using ImageBurn?
By pmolson in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2008, 04:18 -
Making A firmware Update Disc Using ImageBurn Software
By tyfos80 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2008, 10:29 -
unable to install vlc,imageburn,alchol,deamon tools.
By jackyshaikh in forum ComputerReplies: 6Last Post: 9th Jun 2008, 08:10
